[C# - Registry] Piriform registry key not accessible
Hi,
I've find a strange thing on my computer (Win 7 x64 Pro Fr) with CCleaner 3.07 and Defraggler 2.05.
(I've uninstalled both and installer only CCleaner 3.10 with the same problem
This C#.NET code works :
Ce code fonctionne :
RegistryKey CurrentKey = Registry.LocalMachine.OpenSubKey(@"SOFTWARE\Microsoft");
This C#.NET code works too (HKCU) :
RegistryKey CurrentKey = Registry.CurrentUser.OpenSubKey(@"SOFTWARE\Piriform");
This C#.NET code returns null :
RegistryKey CurrentKey = Registry.LocalMachine.OpenSubKey(@"SOFTWARE\Piriform");
Here's the Registry export :
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Piriform\CCleaner]
"UpdateCheck"="1"
@="C:\\Program Files\\CCleaner"
I've checked Registry autorisations.
I've added a manifest file :
<requestedExecutionLevel level="requireAdministrator" uiAccess="false" />.
I've tried overloaded functions :
RegistryKeyPermissionCheck.ReadSubTree, System.Security.AccessControl.RegistryRights.ReadKey
Any idea ?
Thanks,
Vincent
:blink:
Not sure what you are asking or are trying to achieve
Hi,
I need to retrieve default value at HKEY_LOCAL_MACHINE\SOFTWARE\Piriform\CCleaner which contain CCleaner install path only.
Hi,
I've got a partial answer from a M$ forum :
http://msdn.microsoft.com/en-us/library/aa384232%28v=VS.85%29.aspx
I'm using a 64 bits Windows version under Windows 7 were a reflection mechanism is done for 32/64 bits compatibility.
