does C Cleaner ONLY clean the applications it lists under the "applications" tab before running it?
Yes but the cleaning will be both the applications tab and the windows tab at the same time.
So if the app isn’t listed, it can’t delete anything off it?
5 hours ago, catlover84 said:<div class="ipsQuote_contents"> <p> So if the app isn’t listed, it can’t delete anything off it? </p> </div>
Correct, though you can create your own cleaning rules for it (see the link in my signature for winapp2 explaination). Many in the community have made rules already for a great amount of applications so you may wish to ask in the thread for the community template (see below)
