Bug/Help/Suggestion
Hi
I have Speccy v1.04.173 (64 bit) installed and on the hole it looks good. I have noticed that the CPU speed/multiplier doesn't match CPU Zs results when monitoring my overclocked Intel Pentium E2180. Can you tell me if it is possible to out put Speccys temperature readings to a program like the one for the MCubed T-Balancer bigNG. I think I read somewhere the DDR 3 chips have a temp sensor built in to improve there performance. Is it possible to display the value from this sensor?
I need to report the missing temperature display for the Nvidia GT 240... What's up with that... My video card do have the built in temperature sensor. I checked another program and discovered that it does have the temperature sensor, but Speccy had reported that it does not see any sensor for this card... What is going on???
