Browser problems..
Sometimes Firefox doesn't even start up when I try to open it, the process is running but the browser itself does not start up. After killing the process a few times it will start up fine.
This problem occurs in ALL browsers including IE on this computer. I restored the system when it first occurred but that did not fix it. I have ran a malware scanner and other virus scans and they don't pick up anything or fix the problem. I have also re-installed the browsers, but no success.
Any thoughts?
What operating system are you running?
It may be an idea to do what logs you can manage to do from this thread and then post them in a thread in Spyware Hell part of this forum and the spyware mod can then make sure you have no nasties onboard.
http://forum.piriform.com/index.php?showtopic=20120
