Android version. One app uses 146%. Totalling app use comes to 384%. Explain.
i just searched through the android pro and cannot find a battery monitor. can you post a screenshot and I’ll look again. (you should be able to upload one image per post which is better than last month and before where images couldn’t be posted at all
I figured it out. It adds the values for the past 7 or 28 days ( the only options) instead of calculating actual percentages.
ok i think i found it by granting a couple of permissions on my copy, but I’m not going to activate it because 1) you figured it out, if indeed it acts like you say it’s pretty useless to me AND 2)because i find battery monitors to drain in their maintaining services more than inform and most tell me to turn on battery optimization for apps i want running in background.
