My AVG antispyware wont update, when i try - i get this message under Current Status in the Updates tab - "Wrong answer: HTTP/1.0 500 Internal Server Error" ![:huh:]()
What does this mean and what can i do to reverse it?
I would ask AVG's support about this but i'm not a registered user.
The servers could have been down when you tried. I just did it literally 5 seconds before I posted this and it worked fine.
Try it again and let us know if it works.
If you cant get the auto update to work you can download manual updates here:
http://www.ewido.net/en/download/updates/
Thanks for the link! i think it's something on my end... i don't think it's my firewall though. ![:unsure:]()
I manually installed their latest database from the site,, but a message on the lower left of the main interface (lower left) saying it needs to be updated - should i worry about that or not?
