I just ran CCleaner's issues and it found an 'ActiveX/COM Issue' with the file 'avgamui.dll' in AVG's folder ... Do you think this is an error since AVG just came out with 7.5 and CCleaner has not been tweaked for it yet?
I just don't want it to try to ''fix/repair" it if there is nothing wrong with it.
Any info would be appreciated.
Been using 7.5 for a couple of weeks and had no problems deleting what CCleaner finds. If you're worried about it just let CCleaner make a backup before it deletes it.
Do you also have AVG Antispyware and if so, have there been any problems. I just recently added this and have had concerns over losing updates should I check the AVG antivirus and antispyware boxes for cleaning.
Yes I do, and had it when it was Ewido and never had a problem with either. Plus I can honestly say I've never had a problem with ANY application that CCleaner cleans
