Somehow I do not seem to get satisfying good answers from Avast forum(I guess I got used to the extraordinary good answers I get here in this forum.... )
I`ll try my luck here:
In the web shield settings, exceptions in mime types to exclude:audio, image gif ,image/png,txt/css,video
all the above as I understand ,are there by default. Does this mean all files from this kind will not be scanned?
It is not clear why this exceptions are there to begin with, and what happens if I delete these ones ?Will it slow the system down because of the extra scanning?
3.What additional function adds the high sensitivity web shield to the normal? Does the high sensitivity slow down the computer or causes system extra load ?
I'm a new user of avast! Home Free version and quite happy with it.
I was a user of AVG Free until they insisted on my upgrade to 8.0
I tried to be a contributor to its forum but the moderators over there are a bit dictatorial.
I find that the avast! forum is quite helpful but with the range of nasties out on the Internet now it is becoming very hard to not keep a system free from infection.
I have left all of the settings in avast! at their default as I believe they know their application and what the latest threats are.
I have not tried Avast yet. Tried all the other free AV apps. I will have to try out Avast on one of my machines. Sounds like there is a ton of settings and there is no help file available before I install to take a look at. I like to read up on things before I install so I have some idea what to expect. I hate going in blind I find that very annoying.
It would be great if one of you Avast users could provide me with the help file to look at. I know Antivir and AVG built in help files are chm files and easily removed. I would really be happy if someone could provide the Avast built in help file hint hint
I'm sure Avast is a fine program. I tried it about 6 months ago, took one look at the interface, said "Ewwww!" and uninstalled it. Sorry, the cutting-edge designs of 1994 just doesn't grab me, not even in a retro way. I don't think a serious av app should appear as a 1-inch thick blob of silver on my monitor.
Hi Corona
You have got lots of skins to choose from, I`m sure one of these will suit you, if this is your only problem regarding this product.
The media player looking default skin it has I have never liked and never will. However Avast does have the simple user interface that isn't skinned, and during installation you can even instruct it to use the simple user interface or change to it afterwards. It would be nice if they'd make a very nice standard looking Windows GUI for it though.
Well Andavary, they actually have a windows look alike interface ,see below at:
Hey, when I try to download more skins it tells me "There is no application associated with the given file name". I kinda know where associations are but I've never done this before. I never had a reason to.
Anyway, Avast has many files in it. Which file do I associate? And with what? IE7? (I assume IE7, it's not listed as my default browser (duh)).
I know of those. What I was talking about was for them to make a standard GUI built into the main program that isn't a skin. They could take pointers from both AntiVir and BitDefender for making a nice standard GUI. Of course they can still support the skins for those that like them. At the moment the most user friendly skin they have is perhaps the MAC OS skin.
Avast is supposed to automatically install the skin support! You should be able to download then double click a skin and Avast will automatically install it, then immediately show what it looks like after installation.
Yeah but I've noticed lately that that kind of feature is disabled if you don't have IE set as your default browser. Of course there's no option to find out what web site the app is trying to connect to. It's buried.
There was one other skin automatically built within the downloaded app. I changed it to that. Not the greatest but better than that silver blob.
"C:\Program Files\Alwil Software\Avast4\DATA\Skin", and they always work fine.
Of the seven "provider modules", I usually have four running. Unless specifically needed, I disable Instant Messaging, Outlook Exchange, and P2P Shield. Apart from that, I've never changed any settings.
I've never noticed any slowdown whatsoever with Avast in comparison to other AVs I've tried, in fact just the opposite. It seems to run beautifully in tandem with Windows Firewall on my system.
