Automatic Scheduled Cleaning
I have been using your CCleaner for the last one year and am very happy with your endeavours.
Will it be possible that you add on a feature wherein the software could be run at prefixed scheduled timings so that it does it desired jobs and also need not to worry about running it very often, which I do?
Thank You Very Much...
You can use Window?s own Task Scheduler to do this - I don?t think you?re likely to see it in CCleaner for a while.
