auto to sleep rather than shut down
Is there a command line parameter that will put windows to sleep rather than shut down. I had hoped that
Quote
	<blockquote class="ipsQuote" data-ipsquote="">
		<div class="ipsQuote_citation">
			Quote
				start CCleaner.exe /AUTO /psshutdown -d -t 0
	</blockquote>
would work but no luck.
I don't think there's a way to do that currently. But it's a good suggestion.
Thanks for the quick reply. It would certainly be handy for me.
You could create a batch file like the following and name it "ccsleep.bat" for example:
@ECHO OFF
START "CCleaner" /WAIT "%ProgramFiles%\CCleaner\CCleaner64.exe" /AUTO
"<path_to_psshutdown>\PSSHUTDOWN.EXE" -d -t 0
PsShutdown can be downloaded here: https://docs.microsoft.com/en-gb/sysinternals/downloads/psshutdown
1 hour ago, APMichael said:
	<pre class="ipsCode prettyprint lang-html prettyprinted">
@ECHO OFF
START “CCleaner” /WAIT “%ProgramFiles%\CCleaner\CCleaner64.exe” /AUTO
<path_to_psshutdown>\PSSHUTDOWN.EXE” -d -t 0
		PsShutdown can be downloaded here: <a href="https://docs.microsoft.com/en-gb/sysinternals/downloads/psshutdown" rel="external nofollow" target="_blank">https://docs.microsoft.com/en-gb/sysinternals/downloads/psshutdown</a>
Does that wait for ccleaner to finish before psshutdown?
Yes, "/WAIT" instructs "START" to do this.
Syntax:
START "title" [/D path] [options] "command" [parameters]
Options:
/W or /WAIT - Start application and wait for it to terminate.
@ECHO OFF
		PsShutdown can be downloaded here: <a href="https://docs.microsoft.com/en-gb/sysinternals/downloads/psshutdown" rel="external nofollow">https://docs.microsoft.com/en-gb/sysinternals/downloads/psshutdown</a>
Excellent! Thanks for the help
