/AUTO Switch - CCleaner not removing Temp. Internet Files
I'm currently using nnCron LITE to schedule some Windows tasks.
Currently, with the most recent version of CCleaner installed the only way I can remove all temporary internet files is to open CCleaner and click the clean button.
When using the AUTO switch, CCleaner starts, cleans, and exits (in the task bar) but does not remove the required files.
I've reviewed the docs section and searched the forums and have had no luck in finding an answer to this "bug".
Am I missing something or should CCleaner be removing all selected files via the auto switch?
Below are the contents of the .ini file located in the CCleaner dir.
Language=1033
UpdateKey=06/24/2009 06:53:34 AM
IEDetailed=1
FFDetailed=1
CookiesToSave=a bunch of cookies
WINDOW_MAX=1
WINDOW_LEFT=266
WINDOW_TOP=182
WINDOW_WIDTH=620
WINDOW_HEIGHT=450
(App)Old Prefetch data=True
(App)Menu Order Cache=True
MSG_CONFIRMCLEAN=False
Solved:
I resolved the issue some time ago and forgot to post the solution until recently in the event that someone else has a similar problem.
The nnCron LITE service was running tasks with insufficient user privileges as the default setting was not working. The program executed yet the targeted files were not deleted.
Configure the nnCron LITE service to run with *sufficient* privileges by configuring nnCron LITE via the services control panel --> cron --> properties.
*With my configuration it was the local administrator account in which the computer is run. There are no other profiles installed on the local machine and the default administrator account is disabled.*
It's good of you to return and paste your solution, and well done in solving it.
