In Windows XP, is there any way to control the order that auto-start items load at startup?
With Startup Delayer you can add delays, but i'm not sure about the order thing. http://www.r2.com.au/software.php?page=2&show=startdelay
I use Startup Delayer and use it to control the order that programs start in by setting program delay times. I can even stop many programs from running at start up.
WinPatrol has a Delayed Start function but the order can't be re-arranged.
With Startup Delayer, if you drag a startup item into the delay section and decide later that you don't want that particular item delayed, is there a way to change just that one item and set it back to a "no delay" status -- or do you have to start over completely?
