I just renewed my pro subscription. I had the box ticked to do a check, fix problems, then shutdown the computer upon completion. I cannot find that setting now to click so I can still have that happen. Where do I find that box to click to allow me to initiate a check/fix and shut down the computer? I did try to find info by searching but couldn't find the correct verbage to bring about results!
Do you mean Options... Advanced.. Shut down after a custom clean?
