Auto select input YES for popup
Is there anyway to auto select YES after the command CCleaner.exe /delete "c:/temp/*.*" is ran, normally CCleaner will ask for confirmation. It will be useful if it can be done. Thank you.
Is it possible? please someone reply.
I am aware of the ability to launch CCleaner from either a DOS command prompt or a batch script.
I do not know if it can perform as you wish. I think it unlikely - there have to be better ways.
Why not issue the DOS command "DEL c:/temp/*.*"
Regards
Alan
