I use C Cleaner regularly, & have tried the autorun on startup.
My computer is getting on a bit ( ~5 yrs ) & it's moderately slow to start up, and I don't want to increase my start time by autorunning CC on start up.
Would it be possible / feasible to have an option like autoclean on shut down ?
CCleaner has had an "Auto Shutdown" option for a while.
When set up, you run CCleaner, which does it's thing and then it closes down your PC.
CCleaner Auto Shutdown:
Thanks very much for the excellent, prompt reply - it works a treat.
