Auto-Analyze
Add Auto-Analyze option which analyzes auto. saves to press the button
I think it must be enable and disabled , so you can add it in the Advance option .
Helpful especially to me . :D
I can't really see the value in analyzing automatically upon opening the program. One button click doesn't seem worth the effort IMO
It's already a feature! Although you would need to upgrade to the CCleaner Business or Technician Edition in order to use that, as detailed at the very bottom of the page in the Command-Line Options help documentation located here:
https://www.piriform...line-parameters
