ATI Problems.
Hi, while trying to diagnose an error problem i was having with my ATI video card drivers i finally pin pointed the problem. CCleaner was deleting files from the registry that are needed for ATI's drivers.
ActiveX/COM Issue AtiComCloneControl.CloneViewHelper - {4242B984-6C36-4FC8-8626-DE5E8B11886D} HKCR\AtiComCloneControl.CloneViewHelper
ActiveX/COM Issue AtiComCloneControl.CloneViewHelper.1 - {4242B984-6C36-4FC8-8626-DE5E8B11886D} HKCR\AtiComCloneControl.CloneViewHelper.1
ActiveX/COM Issue C4.CCCCom - {CC7C96DF-1942-4D46-9FCD-810EF1C56C2D} HKCR\C4.CCCCom
ActiveX/COM Issue UserInterfaceObject.AtiPropertySheetACE - {872A9397-E0D6-4E28-B64D-52B8D0A7EA35} HKCR\UserInterfaceObject.AtiPropertySheetACE
ActiveX/COM Issue UserInterfaceObject.AtiPropertySheetACE.1 - {872A9397-E0D6-4E28-B64D-52B8D0A7EA35} HKCR\UserInterfaceObject.AtiPropertySheetACE.1
ActiveX/COM Issue WBOCX3.DirectSkinAce.1 - {EB2D089B-51AD-4DEA-98D3-C37A0F3479D7} HKCR\WBOCX3.DirectSkinAce.1
These are needed. If i remove these Catalyst Control Center from ATI errors out. It is still happening with the current 2.18.878 and i am using vista 64 bit.
This is a very old BUG !!! which the devs of CC are not willing to FIX (it seems, since it's there from the beginning) :angry:
This is TO BAD ! Because of it me and all my friends STOPed using CC a while ago after being a VERY enthusiastic CC user (used to recommend it to everybody) :( Imagine what's happening with other less common drivers / apps ! :blink:
@DEVS
WHAT'S HAPPENING WITH CC ? :wacko:
Read this to learn how to Exclude items in CCleaner.
Hi,
I am sorry to hear that you are having problems with CCleaner and Catalyst Control Center.
Would it be possible for you to export the keys being removed into a .reg file(s)? Once exported you can email me directly or post them on this forum.
The idea is for us over here to import those keys into a test machine and verify why they are being presented as not needed.
Thanks
