Applications not showing up?
Well just like the title says, a lot of my applications aren't included under the applications tab so they don't get cleaned. On my desktop the programs are detected just fine, but on my new netbook ccleaner just doesn't seem to detect them. Sorry if this is a common question, but I couldn't find it anywhere. So how can I get my applications included?
Perhaps you should say what Applications you mean?
A lot of Applications actually, I figured ccleaner would auto detect them or whatever like they did on my desktop but it doesn't seem to be doing that.
Just to name a few:
Microsoft Office
OpenOffice
Media Player Classic
KMPlayer
There are a few more, but I guess those ones could be called the more pressing ones. In the end I guess those not being cleared aren't that big a deal, but I just wonder why it would work on my desktop and not my netbook.
Have you installed them to a different drive?
Or running a different version of those apps than on your other PC?
CCleaner looks in specific places for apps, so if you install an app to a different partition/drive or if a newer version of the app changes something the detection may drop from ccleaner.
They are installed to the same drive as CCleaner, although with both the Office programs I think they are indeed newer versions than I have on my desktop. However the others are the same as on my desktop and still they do not show up.
