anything more than ccleaner?
i've played around with a lot of software and i keep coming back to ccleaner for its simplicity and effectiveness. i am wondering if the majority of people feel that ccleaner is enough to keep a computer in top shape or if more programs are needed, such as tuneup utilities or something.
i use avast as my antivirus and malwareantibytes to supplement.
i've tried and got rid of advanced systemcare, tuneup, system mechanic, comodo system cleaner, other iobit products and well pretty much any of those. yes i've probably screwed my computer up playing with so many.
anyways i keep coming back to ccleaner and want to keep it simple from now on. do you feel that ccleaner and defraggler are enough to do so?
CCLeaner is what I use for all my junk cleaning (except Internet Explorer because I keep that clean after every browser close)
CCleaner can be expanded well beyond its default settings via winapp2.ini, so having other cleaning tools really isn't necessary.
If you mean something beyond cleanup, I use Auslogics Disk Defrag, Revo Cleaner.
Security: ESET Smart Security, HOSTS Files, SpywareBlaster.
