Annoying context menu entries
Hi,
There are some programs that adds context menu entries, it would be a good feature if ccleaner has an option to remove these entries ( for users who don't know how to remove them directly from regedit, I had to search the web to find out howto remove it ), some of those programs do not remove these entries even when uninstalling them.
btw, I've found how to remove here: http://www.askvg.com/how-to-add-remove-ent...-context-menus/
I love this suggestion... a place to manage context menu entries as a new tool inside CCleaner... ;)
Although NirSoft makes two shell extension disable/remove tools (ShellExView and ShellMenuView) this is a very good suggestion for CCleaner.
I'd like to see it included someday too with the ability to:
* Disable
* Completely remove
