- In Win XP the standard photo/picture viewer was able to "play" animated GIFs. It recognized that a picture was an animated GIF file and was able to show the animation.
- But the picture/photo viewer that came with Win 7 doesn't "play" the animation anymore.
- I tried IRFAN but the program had its own ideas what the proper "play" speed should be for the frames inside the GIF picture. Sometimes it was (way) too fast compared to the standard build-in photo/picture viewer (in XP) or in the browser (e.g. Internet Explorer of Firefox).
Open Windows Media Player and then select open in the menu. When you browse for the.gif file make sure you select 'all files'' in the little dropdown box at the bottom.
- After a lot of GOOGLEing (GOOGLing ???) I found this program on the MAJORGEEKS website that plays these animated GIF pictures (surprisingly !!!) well. After installing of the program can select a *.gif file. The *.gif file will be automatically opened with this program. The program is a viewer for *.gif files only. It will skip all other files that are in the same folder.
