using a laptop with windows 7 64-bit
If I defrag my drive and than analyze again the analyze is alot different than what it said the current state was after the defrag. Is this a bug or what?
current state after a defrag
1 fragmented files
6 fragments
26% fragmentation
analyze again right after and get
5 fragmented files
14 total fragments
29% fragmentation
Have you tried excluding "System Volume Information" from the defrag?
You can't defrag these files as they're in use, and Windows is adding to them as a matter of course, probably through "Shadow Copy", which backups files which are moved or modified.
I excluded the folder now I'll see what I got now.
No my analyze after a defrag is still different after excluding that folder.
Yeah, I'm going to look for a different defrager.
