Alcohol 52% cleaning
I noticed that CCleaner can clean the MRU for Alcohol 120%, but it doesn't do it for 52% (I use the free edition). Could it be added in a future update?
The reg key used is:
HKEY_CURRENT_USER\Software\Alcohol Soft\Alcohol 52%\MountedMRU\0
Great little prog btw!
Thanks to fredvries, here's how to add support for 52%:
Copy and paste this into C:\Program Files\CCleaner\winapp.ini (or winapp2.ini if you have the extra cleaning provided by Twisted Metal)
[Alcohol 52%]
LangSecRef=3024
Default=True
Detect=HKCU\Software\Alcohol Soft\Alcohol 52%
RegKey1=HKCU\Software\Alcohol Soft\Alcohol 52%\MountedMRU
Tested and works a treat.
Many thanks!
