After Using Recova
Good Morning.
I need some urgent advice if anyone can help.
Last night I discovered that files and folders were missing from the desktop folder. I believe this happened by running an uninstall exe for software from the desktop.
I used recova to restore the files it could find that had been delted from that directory.
Only problem is that there were a lot of files there and not as many have been recovered. I also need to recover the folders and structure.
Is there a way of doing this?
When I used recova I recovered to the same drive. Will this affect chances of full recovery.
Any help will be appreciated. Thanks
Also. I realise that Recova may not be able to recover the folders / structure. Can anybody suggest anything please?
It is 100% better to recover to another drive such as a usb stick or external drive, in fact it is really a must.
Also you can select 'restore folder structure' as a post here shows
http://forum.piriform.com/index.php?showtopic=23991
Also the documention may help you by giving more info on Recuva.
http://docs.piriform.com/recuva
