advice on System Mechanic 6 vs. System Mechanic 8
You all seem like very knowledgeable people when it comes to PC tools etc., so I would like your opinion on the following:
I currently have System Mechanic 6 and I would like to know if there is much difference with System Mechanic 8 (i.e. Is it worth spending the $19.95 to update)?
Again, thank you all for your time!
Quite frankly, System Mechanic 8 is superb. The previous 7.x wasn't too hot, primarily as it was released as a Vista tweaking tool, shortly after Vista, which led to various conflicts with the new OS. However, 7.5 came out at the end of last year and recently v8.x
For ?10, it's no brainer. Indeed, I managed to get a 2-year license for ?14 recently with their 60% off promotion.
Chris/vnunet.com
Thank you Chris for the info, I appreciate it.
