Advanced SystemCare 3 by IObit
Has anyone tried IObit Advanced SystemCare 3 (free version) or heard anything about it.
http://www.iobit.com/advancedwindowscareper.html
Just want your trusted opinion on this.
Just want to hear your trusted opinion on this.
I used it from its initial release ( it was called Advanced WindowsCare ).ASC and CCleaner worked perfectly.No problem at all. ASC has more feature than CCleaner like Internet Booster that make my connection faster and also Backup supported.
I also have used the initial release, although I won't venture back into using it.
You think using the program could cause problems or you just use various programs to accomplish the same tasks?
