Advanced System Care 1901 158 Free Crashing
The new CCleaner version is causing a restart and here is the dump. Its on Win
11 Home.
Conflict is crashing Win 11
Hi @Toadsy,
Do you know what version of Windows 11 you are running?
Windows 11 Home updated on 10/14/25.
@Toadsy please click the Windows button and type winver. This will open a window and in this, it will tell you what version of Windows 11 you are running. Please let me know this so we can investigate this further.
Just received an update and I am now on 25H2.The issue should be easy to recreate.
I also had several bluescreens on the 25h2 build.
It happened even at idle. Rebooted just doing nothing at all.
Are you sure it is CCleaner 7 that is causing this?
There’s the big test of that of course.
If you uninstallt CCleaner 7 then does the bluescreening and the crashing stop happening, or not?
Yes.
Hi @Toadsy,
I have sent you a DM for more details on this issue.
