Hi,
I like RECUVA in the main, but as I am trying to recover two 1TB disks it would be very handy to be able to filter results by EXT, size, status etc. Adding columns and double clicking to sort would be good
I hope this is not there already :-)
Hi,
You can filter on any part of the file name or path by using the File/Path box on the top r/h. Recuva will still scan everything first though. You can sort the columns in the usual way by clicking on the column header.
