V229.1111 won't analyze or clean Advanced>Custom Files and Folders. The folder I included is C:\Sandbox\*.*
I reinstalled V228.1091 and it works fine. My system is XP Home SP2
Hi jlhns, and welcome to Piriform.
I think the latest version needs the "Recurse Subfolders" box checked:
Hope that helps, and you should really upgrade to SP3, as support for SP2 ends on July 13th this year.
http://support.microsoft.com/ph/6794
If you need any advice on that just post back.
Thanks Dennis, that worked.
As for SP3, I've tried to upgrade twice and both times I got the blue screen of death which necessitated a complete OS and software reinstall. I decided not to try for the third time's a charm. If I have major problems after support ends for SP2, I'll just get rid of this four year old Dell dinosaur laptop and get a new one.
Thanks again.
If it's any help, there are a few ways to update to SP3, all of which are described in the linked to page.
I opted for downloading the ISO file and burning it to disk. This gave me an SP3 backup CD in case I ever had to reinstall Windows, which would have taken me back to SP2.
There's also a link to an MS page describing how to prepare your PC for the upgrade, including removing certain MS Updates which make the install fail.
http://www.pcworld.com/article/145810/inst...this_first.html
Apologies of course if you've already looked into all this.
You can also make a slipstreamed/integrated XP install CD (or DVD if you fancy) with SP3 already built into it, of course that means a reinstall just to have SP3 so it may very well not be worth the hassle. Such a free tool that allows such is nLite which I've used with success.
