CCleaner appears to clean flash cookies, but references to the websites whose flash cookies have supposedly been removed by CCleaner remain on the Adobe flash player settings manager after CCleaning ...
Are these website references just empty folders ?, or should they have been removed by CCleaner ?.
those cookie are gone however yes flash will still remember the sites. This is discussed much and the only way to remove one entry (other than through the screen you refer) is to remove ALL entries by deleting settings.sol from
Do you have those sites listed in 'Cookies to Keep'?
The Yahoo login cookie was the only one I deliberately kept.
When regular (not flash) cookies are cleaned not a trace remains.
So I was just concerned about the references to the websites remaining in the "Adobe flash player settings manager" after CCleaning flash cookies, (e.g. Google mail).
Hi, could you please tell me how you got that screenshot? I think it is in adobe flash player settings. I checked my program, flash player is there, I can't find way to open adobe flash player settings. step by step instruction please.
Hi, I have adobe acrobat installed. There is a feature "web capture" under "advanced". Every time it make a PDF file from a web site, the url recorded on the list. ccleaner does not clean that list.
Is something I need to do specifically in the settings, ccleaner's or acrobat?
Thanks in advance for all your input.
