First of all thank you for a great program.
May I suggest that you add a feature to determine and remove broken CLSID's.
Second, if there is a way of cleaning registry debris from uninstalled printers, this would also be useful.
I'd like to delete viewed email and newsgroups pictures in Outlook Express.
Messing with Outlook Express' fragile dbx files is the best way to kill that Identity's email store.I'd like to delete viewed email and newsgroups pictures in Outlook Express.
As Yokenny says messing can lead to problems.
However here is a good link (for looking at) with tons of info on email settings and just about everything else to do with emails
http://email.about.com/cs/oetipstricks/qt/et101202.htm
The ''all email tips'' lists quite a few types of email with all the tips on how to use them.
I have been using Cyber Scrub for several years to delete email and newsgroup pictures. Never had a problem.
At $49.95US I'll pass on it.I have been using Cyber Scrub for several years to delete email and newsgroup pictures. Never had a problem.
