Add cookie to keep
I would like to (manually) add a cookie to keep (Options - Cookies) https://bard.google.com/ . I want to add just this domain, I don't want to add www.google.com which is the only cookie that shows up automatically on my computer. I think it is a big handicap that I can't add an exception manually!
I tried to disable Edge to clean cookies at exit, FlashPeak browser, but bard cookies wouldn't show up automatically in Ccleaner options. So, every time I run Ccleaner I need to login again to my bard extension.
If you right-click on the Cookies to Keep pane, it will bring up a context menu with an Add option. If you click that option, you'll get a dialog where you can enter the cookie domain - bard.google.com.
However, I'm not very sure it will do what you expect. From the fact that bard.google.com cookie isn't listed in CCleaner and from my experiment with a web login to Bard, it seems to me that the login you want to protect is stored in a google.com cookie. This means that protecting bard.google.com cookie wouldn't have any effect, simply because there is no such cookie.
13 hours ago, rofoun said:
Thank you @rofoun for the detailed answer. It looks like I need to keep google.com cookie in order to work. Thanks.
