Add Applications
Gentlemen:
I love and use all of your products, and I have donated money to you. I recommend your products to my friends and colleagues, and I also suggest that they donate to you. There is one thing I would like to have the ability to do. That is to add icons to the tools bar so that I could invoke other applications. Specifically I use the following programs whenever I invoke CCleaner:
Whats Running( http://www.whatsrunning.net/whatsrunning/main.aspx ),
CodeStuff Starter ( http://codestuff.tripod.com/products_starter.html ). and
Revo Uninstaller ( http://www.revouninstaller.com/ )
The combination of CCleaner with these applications make for a powerful maintenance utility. Is there any way I could do this? Or perhaps you can add this feature in the future. Thank you for your consideration.
Please do not use my idea, I suggested it in the previous topic, Gentleman! :angry:
