Add a system temperature alert.
Hello, I'm going to try to speak in English, as It's not my mother tongue.
I want to suggest the inclusion of a option to configure a alert when the (CPU, HDD, etc) surpass a given temperature, for example: I want to know on time when my CPU temperature reach 80 degrees celsius.
you mean an audible alert?
Speccy can already do a visual alert in the System Tray with the temperatures (although in the past there have been a few bugs with this method, not sure if they are fixed yet - like it not auto starting when told to do so)
have you investigated the BIOS motherboard settings?
most newer boards have settings that control fan speeds, offer alerts or even shut down the PC when certain, user-set thresholds are met.
