Adblock Plus extension filter settings reset in MS Edge
Running CCleaner resets the filter settings of Adblock Plus in Edge. I've had no luck trying to find the necessary exclusions other than disabling some Edge cleaning entirely.
I believe this issue is being investigated by the Ccleaner devs.
Great, thanks, hazelnut! Can you please keep us posted on their progress?
Yes I will :)
Hi! Any updates on this? :)
I promised I will post when there is news and I will :)
I ask the devs for updates about this regularly.
