about IOBIT SmartDefrag !
New version SD (1.30) was available at SOFTPEDIA,yesterday. I downloaded and installed over the old version in my primary PC and set automatically at wins startup.
everything runs fine and this morning, after booting :
1. Avira Guard stopped and cannot opened via tray icon !
2. A-Squared Anti Malware guard / real time protection also stopped !
I tried to find the answer and roll back to previous state ( before SD 1.30 installed ) and everything back to normal.
I don't know if new version SD caused this problems, just guess :unsure: . After all, I completely removed SD and use Auslogics as my top defrag program in my primary PC. ;)
anyone has same problem ? IOBIT again ?
i think this one install a toolbar...did you check when you installed?
Unchecked ;)
IOBIT again ?
probably, not worth trying with their reputation:
http://forum.piriform.com/index.php?showtopic=25072
My thoughts exactly, so lets not plug them at all on the forums. If they can clear their name then fine, but I don't see that happening.
I think I had a few problems with Iobit in the past, but as I dont use their software anymore, I cant really comment on their newer stuff, stick with software you know and trust.
