About design of Cleaner results panel
I don't like the new design of Cleaner results panel because the plain text design accomodates me much better.
Can be add an option for viewing Cleaner results panel as plain text?
Right click on them and select view detailed results.
The you can right-click on them and save as text file as well.
I suggest if is possible for the next versions to give us the ability to select between the old and new style by an option in options tab.
Thank you
Love the new results panel and the detail results option. My suggestion would be to automatically include the horizontal scroll with the detail. The beginnings of the details are pretty generic and you have to get to the right end to see some meaning but it is now pre-abbreviated. I know of no way except to keep "pulling" the title bar, but it won't stay that way.
