A small Suggestion
Hi, there.
Speccy is a nice little monitoring tool. Really like it. Keep pushing it higher up with good quality updates as you always have done with your other products, Piriform.
The minor suggestion I'm thinking of is if you could add a 'check-for-updates' button/function like for example in CCleaner. It'd be really sweet and foremost very handy. :)
