A Small Question
Awhile back I downloaded the CCleaner guide in its ZIP container and kinda ran the guide while it was in the container. To the point, I punched some things into the search and now it's permanently in the search bar should I open up the guide from its container (see attached). I'm just curious, is there anyway to cleanup that data (CCleaner seems unable)?
Try extracting it from the zip file first.
I extracted the contents and on open, that one has a blank search bar. I ran CC again, and doubled check the zip container. The searches are still present in the file in the ZIP container.
But why are you wanting to run it in the zip folder? Just extract it and delete the zipped copy.
Oh I'll definitely run it from extraction, but judgment failed me the first time and now I've got some random data related to that zip file. I was wondering if there was a way to clear that up.
