A small computer problem..
I just updated Mozzila Fire fox and when I make errors like in this forums I can't fix them anymore, I click on the right side of the mouse click thing but nothing scrolls down..Not even when I try to copy something, I underline it but I can't copy it because nothing happens when I click the right click thing of the mouse..
Any help. :| :unsure:
Psss how can I change my piriforum password?
HEEEEEELP!
I am unable to paste copied text or fix grammar errors using the right click method!
I'm guessing this has something to do with Firefox 3.5..
I don't think so!
Does it work on your desktop?
To change your password go to 'my controls' (top of forum page)
Then look under Menu on lefthand side of next page.
There you will see Options futher down that list.
One of the options is 'change password'
I don't think so!
This is a desktop...
The right click method works fine on Internet Explorer tho.
Thanks.
