Looks like this is a new sort of tool to help with install/uninstall problems ( with a program that used the Microsoft Installer) similar to the old Windows Installer Cleanup Utility.
http://support.microsoft.com/mats/Program_Install_and_Uninstall/en-us
More info here
http://blogs.msdn.com/b/astebner/archive/2011/11/23/10241056.aspx
I've just put that onto a flash drive to check out. Looks good.
I have to say your "queen of the links" title is very very safe. ![:)]()
I also saved it to try out. Right now, I still use the older cleanup utility for MSI installer fixes.
Thanks, Hazel!
Thanks Hazel.
It's nice to have a lightweight portable version to test out.
Is it possible that someone writes about those tests?
I am using Advanced Uninstaller and I somehow have the feeling there might be something better out there...
Thanks
Hi John.
Have you tried any of the following ...
Revo Uninstaller: (Choose Freeware Version Option)
ZSoft Uninstaller: (Install Tracker - Freeware)
Total Uninstall 2.35: (Install Tracker - Last Freeware Version)
All very good at what they do.
