5.42.6499 does not install correctly
after install today the version still says 5.42.6495 .
Also cleaning does nothing make the gui disapper. Task manger show ccleaner running with /monitor switch.
I tried uninstall manually and then install. Still no joy.
try this;
uninstall your current version first.
then go into the Program Files folder for CC and delete its contents
    (keep the .ini file if you have customised settings)
download the latest build from here; <a href="https://www.piriform.com/ccleaner/builds" rel="external nofollow">https://www.piriform.com/ccleaner/builds</a>
reboot the PC then install CC from your downloaded file.
if no luck, try the install with the PC in Safe Mode.
and try the Slim or Portable builds to see if they work.
I am having the same problem. But I think it is because the new version is not correctly uploaded. Because the page where you download the latest version still says I am downloading v5.42.6495.
21 minutes ago, Joseph29 said:
You should be able to get .6499 at https://www.ccleaner.com/ccleaner/builds
Are you saying that page is serving .6495?
after doing as mta said I got 5.12.6499 to install but it will not clean anything.
It finds stuff when you Analyze but when you "Run Cleaner" the app dissapears.
When you open the app again and Analyze, you get the same files in the list.
Nothing in Windows logs about this program.
I am having this same problem and have had with the last two versions.
This is a known issue with 5.42, don't quote me but I believe a fix is due in 5.43
Same issue here :(
sounds like v5.40 should be the stable version everyone reverts to until the mess that is v.42 gets resolved.
OK, I'm missing something here...
is v5.42 not a mess and did v5.40 have critical bugs?
I installed the newest version V5.43.6522 (64bit). It still does not clean. The Windows application log has this:
Fri.Faulting application name: CCleaner64.exe, version: 5.43.151.6522, time stamp: 0x5b06f9ea
Faulting module name: CCleaner64.exe, version: 5.43.151.6522, time stamp: 0x5b06f9ea
Exception code: 0x40000015
Fault offset: 0x00000000005b9f36
Faulting process id: 0x16cc
Faulting application start time: 0x01d3fe86694c1e75
Faulting application path: C:\Program Files\CCleaner\CCleaner64.exe
Faulting module path: C:\Program Files\CCleaner\CCleaner64.exe
Report Id: a7982588-6a79-11e8-b790-902b34da1143
This is on Windows 6.1(build 7601:service pack 1) .
some known issues with the version of CC you are using is with Kaspersky and MalwareBytes, do you use those?
in the meantime, revert to an earlier version of CC until the next release.
previous versions are available from FileHippo.
Yes they're located at: https://filehippo.com/download_ccleaner/history/
