3.08.1475 and Java
I have removed Java from my pc but it left the Java icon in the control panel. The icon left is a generic windows icon and not the Java logo. I was expecting the Registry scan to find that error but it didn't.
- I'm using CCleaner 3.08.1475 and Windows Vista SP2 64-bit
- I've restarted the computer
- I've ran the registry cleaner multiple times
- All options are checked in the Registry Cleaner
- The Java program is not listed in Add/Remove programs or in the Uninstall tab in CCleaner
- No Java directories found on the drive
- The Java icon info in the registry is present in HKEY_CLASSES_ROOT\
Keith G
