Speccy shows 2GB memory instead of the actual 6GB for GTX 1060 6GB GPU.
you aren't alone.
double check you have the latest driver.
also see here; https://forum.piriform.com/index.php?showtopic=47684&hl=wmic&do=findComment&comment=279900
do what I suggest in post #2 and report back with your findings.
