10Mb connection ?
Can someone help me out i am with Pipex i pay ?25 or something like that for 512Kb then i got a Gmail saying they are upgrading me for free to 1Mb then on upgrade month i get a 2Mb connection. So i thought very cool indeed then as you may have read around the forum im having problems with my connection keep drooping i reconnect as usual and it now says :blink: 10mb :blink: . Would they actual upgrade me from 512Kb to 10Mb for nothing extra.
i assume it would be free. btw what reason does ur internet lose its connection??
just to make sure its not an error u should test ur connection to see if it really is 10mb
Sadly your connection isnt 10mb. If I look at the network connections screen this is what I get
I think thats just how fast your sending info to and from your provider not other servers. I wish my connection was 100mb :D (If I test it on the site that you went to I get 4mb).
hey, out of curiosity, thats a cool skin for FF. whats is called? and could i get a link to it?
also, what are you using to skin windows?
thanks
)corjello(
Its really how fast your network card will go...
if you're talking about rridgely's Speed thing then yes. however that isnt the real speed since your ISP limits the tranfer tate ;)
http://en.wikipedia.org/wiki/Network_card
thanks
)corjello(
I forgot the site i got them from tho it was likely deviantart so i have uploaded them to the brilliant uploadr site. Click here to download.
