Hi,
I have this error when trying to view chipset information, I have tried re-installing drivers.
Any ideas what it could be? is this a sign theres a problem with the motherboard?
Here is the snapshot if anyone would like to view it ;-
Hi,
The most current version of Recuva was released on June 2016, if your hardware (including BIOS) is newer than the software examining it that may explain things. You can always get a second opinion with other similar freeware tools.
4 hours ago, Andavari said:<div class="ipsQuote_contents ipsClearfix" data-gramm="false"> <p> The most current version of Recuva was released on June 2016, if your hardware (including BIOS) is newer than the software examining it that may explain things. You can always get a second opinion with other similar freeware tools. </p> </div>
Think he means speccy ;-)
