1,5GB keep reapppearing
Hello,
I have problem with CCleaner v5.05.5176 (64bit). It can not delete the 1,5GB of files, no matter how much I repeat the process.
Files are not in recycle bin, I can not see them. In the log text is showing some iOS photos. For example:D:\$Recycle.Bin\S-1-5-21-649741799-2634740036-349902210-1001\$RJ8FB6K\20140510_121443725_iOS.jpg 1,787 KB
I tried icloud for windows, but I uninstalled the service. I don't have onedrive sync turned on, I'm using local windows account.
I'm using Windows 8.1 pro, 64 bit.
Screenshot and log file are attached.
Thank you.
log.txt
Looks like you may have a corrupt recycle bin. See fix here
http://forum.piriform.com/index.php?showtopic=42673
Thank you hazelnut.
Problem solved.
Thank you hazelnut.
Problem solved.
Good to hear and welcome to the forums :)
