0x6 the handle is invalid. Suggested fix does not work. Can not update to 6.40.11558 On a Win 11 PC
6.40.11558 is a maintenance update for older Windows versions
See here
Thank you very much. So that is reason it would not do anything for win 11.
Greatly appreciate your help. From, Pete & Grace Reno Rimersburg, PA
hazelnut: This was a new install on my wife’s PC and I tried the update as soon as I got done and got this problem. If I had waited as you said, the automatic update would have done its job and I would not ran into this problem. Greatly appreciate your help.
Hi @Laurence_CCleaner :
I checked the official CCleaner builds download page and can confirm that the download button for the Standard installer for Win 7 (“sunset” release) is now offering ccsetup640_win7.exe (rel. 16-Apr-2026), but the download button for the Portable build is still offering ccsetup639.zip.
Do you know if Piriform/Avast intends to release an updated ccsetup640.zip for the Portable build?
____________
Dell Inspiron 15 5584 * 64-bit Win 10 Pro v22H2 build 19045.7184 * Firefox v150.0.1 * Microsoft Defender v4.18.26030.3011-1.1.26030.3008 * Malwarebytes Standard v5.5.4.252-154.0.5578 * Macrium Reflect Free v8.0.7783 * CCleaner Free Portable v6.39.11548 * HDCleaner Portable 64-Bit v2.095
@lmacri
Portable didn’t need the version update, because all that changed was whether the updater errored out on update, it now, if I understand correctly, will update to 7 or tell you you’re stuck with this version (for win7 users), which is something portable doesn’t need. Though I agree it is a bit fragmented without portable bumping version too
Hi @lmacri,
Thanks for flagging the v6.39 of the portable build.
A v6.40 was built by the development team and the link has now been updated.
If you have any more issues with this, please let me know.
