CeeCee Posted April 23, 2007 Share Posted April 23, 2007 I bought another S-ATA drive, i already got one. Problem is, that programs that can publish S.M.A.R.T. data, show same info for both drives. Even model- and serial number are the same for both drives. Only 'seek error rate' and C3 (unknown attribute) are individual on both drives. I enabled S.M.A.R.T. in BIOS, but that didn't helped. Both drives are Seagate Barracuda S-SATA. First drive is ST3200827AS and this new one is ST3250624AS. Can anybody tell what is wrong? EDIT: Found this from VIA forum: You will only be able to SEE the Smart Status of the SATA connected to the Channel 0 on the VIA Controller if you use a windows based utility such as Everest Ultimate. Even if you use the SeaTools Diagnostic running on a floppy disk during boot you will only SEE (1) of the SATA's Smart Status. This does not mean that your 2nd SATA connected to Channel 1 is not reporting Smart Status but the data is not being forwarded from the controller most likely because the architecture of the controller is a PCI-ISA Bridge. Visa versa if you switched channels then one channel will report the Smart Status If you for instance you had 2 SATA's either standalone or in a RAID Array on the Promise-378 Controller both drives Smart Status will be available both in windows as well as by the SeaTools Diagnostic because the architecture of the Promise-376/378 Controllers is straight on the PCI Buss. Path Copy TeraCopy Unlocker Link to comment Share on other sites More sharing options...
Moderators Andavari Posted April 24, 2007 Moderators Share Posted April 24, 2007 I don't know a whole lot about hardware, however you may want to give HD Tune (freeware, no adware, no spyware) a try as it can also detect the S.M.A.R.T. status. Link to comment Share on other sites More sharing options...
