argen Posted April 14, 2007 Share Posted April 14, 2007 Hello: 1) Automatic Windows Update was downloading (or installing, I don't remember exactly) new critical updates, and I have run CCleaner at that moment. It was three days ago, and Windows still didn't install the critical updates, I think that CCleaner deleted something that Windows was using in that moment. 2) Every time that I run CCleaner, it reset the customization of the Internet Explorer toolbar and I have to reorder it again. What Should I uncheck at the options to avoid that? (Anyway, I think that CCleaner shouldn't do that). Thanks. Link to comment Share on other sites More sharing options...
fireryone Posted April 15, 2007 Share Posted April 15, 2007 you shouldn't EVER run CCleaner while installing or updating an application or operating system, as it will do its job and remove all temporary files (which is where some programs uncompress files to while uninstalling). fireryone Link to comment Share on other sites More sharing options...
Moderators Andavari Posted April 15, 2007 Moderators Share Posted April 15, 2007 With Internet Explorer visit http://update.microsoft.com/ and see if it will install those updates. If it won't click the links the updates have (something like more information or something along those lines) and follow it to the KB article/download, etc., then download and install those updates from a downloaded .exe file. Link to comment Share on other sites More sharing options...
argen Posted April 16, 2007 Author Share Posted April 16, 2007 It finally installed the updates automatically. Thanks. The other question remains: why CCleaner resets the IE tollbar arrangement? Every time I run CCleaner I need to personalize it again. I think if one changes the address bar location, adds/removes buttons, hides links bar, etc., it's someting that CCleaner should keep. Thanks again. Link to comment Share on other sites More sharing options...
